Hi All - I'm getting tired of buying and storing the chlorine tabs that my pool builder started me off using when my pool was built a year ago. I have the TF-100 test kit and have noticed my CYA levels creeping up near 100 which I don't like. I'm considering retrofitting a SWG into my pool, but have some questions about it.
My pool uses Hayward equipment (VS pump, heater, Omnilogic automation) and is approximately 9000 gallons including the spa. I also have a Paramount in-floor cleaning system. I reviewed the plumbing situation and there doesn't seem to be a convenient place to install the SWG other than on the pipe feeding the in-floor cleaning system. I understand that installing the SWG on that pipe means it won't chlorinate the pool if I shut off the in-floor, but it's on 99.9% of the time. Would it be a bad idea to install a Hayward AquaRite on this pipe?
I'm also curious how big of a cell I should get. The T-Cell 3 says it's good for up to 15,000gal and my pool is about 9,000gal. However, I've seen on the forums you should oversize the cell. I also live in the Phoenix area, so the pump will run 365 days/year for 8-12 hours a day at various speeds. Would you recommend oversizing further and getting the T-Cell 9 rated for 25,000gal?
Any other advice for someone considering a DIY install of a SWG like this?
Thanks in advance!
Thanks in advance!
