I replaced a 1.5hp 2 speed Haywood after the bearings went out for the third time. I installed (DIY) a Pentair Superflo (342001) and it is now running. However, I have a pressure side Polaris 360 cleaner and it seems that the pump is not powering it adequately at the highest default speed of 3000. When I pick the Polaris out of the water it is obvious that the water flow from the rear nozzel is much less than with the Haywood. It does seem to do better at the Pentair's 'self priming' speed of 3450. The Haywood had no problem moving the Polaris around on its high setting. Anyway, I am wondering if I can set one of the variable speeds higher than 3000 - the speeds and timing of each speed is customizable - or if there would be issues with doing that. The manual does not address setting it above the highest default speed- the default speeds are 3000, 2200 and 1400).
OR, will this pump work better with a suction side cleaner. I have had the Polaris for 20+ years and with all the new parts and rebuilds it is sort of like new but a cleaner is so essential that I am willing to change if it makes sense. BTW: pool size is 36 L x 18 W by 4' at each end sloping to the middle at about 5 feet plus. Anyway. . . otherwise, pump seems fine and easy to manage the controls, but I am wondering about this issue, and over all power for filter and cleaner. (Filter is a quad 60 sq foot cartridge unit).
Any help will be greatly appreciated!
Ron
Ron
