I had to take down the pool I had due to severe rust. I have purchased a Intex 16' x 48" Ultra Frame Krystal Clear Cartridge Filter pump 1,500 gph as well as a Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 3000 GPH Pump Flow Rate, 110-120V with GFCI. I am going to attempt to put it up next weekend. I still have my INTEX® 120V Krystal Clear Saltwater System so I am in desperate need of advice on installation, compatibility, rust prevention, & testing.
So here I go
I am leveling my yard any advice best way to level?
hope to put a walking deck around the pool only about 12 up can I put the pool on a wooden deck?
What material other than the cloth that comes with the pool would you put under it? Foam board was suggested.
Equipment
Can I run both the pump that comes with pool (Ultra Frame Krystal Clear Cartridge Filter pump 1,500 gph) and the Krystal Clear Sand Filter Pump for Above Ground Pools, 3000 GPH Pump Flow Rate, 110-120V with GFCI together?
Can I utilize my INTEX 120V Krystal Clear Saltwater System with any or all of the above?
Rust prevention
Is there anything I can apply to the pool frame to prevent rust prior to assembly?
Testing
Just ordered the TF-100 Test Kit Will this do the trick?
Thank you ahead for any and all advice.
I want to learn so that I can then return the help.
My signature line hopefully will be changed the next time I post to reflect the positive new information
So here I go
Equipment
Rust prevention
Testing
