Greetings! I'm in the midst of a largely DIY inground pool build - 36x18' rectangle with 90 degree corners and using polymer walls. Will be getting a contractor to pour the collar next week so just double checking everything. I'm off just under 1" corner to corner - would need to shift by about 1/2" to square perfectly. It's going to be some work to do that as I've got it all staked in at this point. Sketchup tells me that's 0.3 degrees out from 90 degrees. Is that an acceptable variance or should I suck it up and square it?
