Information onslaught is severe!
I feel this builder just wants to keep on tacking on ridiculous charges. He quoted $13,000 to install a fiberglass in ground tub that runs off my pools filters, pump and heater. Meanwhile a separate well known and respectable fiberglass pool company quoted $15,000 with all separate equipment installed. Same tub. :grrrr:
Main Drain with 2-inch Suction Outlet for Vinyl & Fiberglass Pools.
ITEM # WG1049AVPAK2
http://www.hayward-pool.com/prd/In-Grou ... 400186.htm
Skimmer with 2-inch Suction Outlet for Vinyl & Fiberglass Pools.
ITEM # SP1084
http://www.hayward-pool.com/prd/In-Grou ... 0196_A.htm
Skimmers - Vinyl
506423 2 in. Slip ports, white
http://pentairpool.com/pool-owner/produ ... nyl-14.htm
StarGuard® 8-inch Round Main Drain Two Port (2” NPSC Side x 1-1/2 “ NPSC Bottom)
Installation for Vinyl Liner Pools (Model 500130)
http://www.pentairpool.com/pdfs/Stargua ... rainIG.pdf
8" StarGuard drain w/2" side & 1.5" bottom vinyl liner ABS sump (2 pack), white
http://pentairpool.com/pool-owner/produ ... in-402.htm
Even if the skimmers, main drains and/or returns only came with 1.5 inch fittings, that would not preclude running 2-inch from the system to the pool. However, they do come in 2-inch and, in my opinion, that is what should be used.
Maybe since I need black skimmers and returns that they only come in 1.5". But that's not what the PB was implying.
I'll have to see if I can contact Hayward or Pentair myself.
Thanks for the links James! :goodjob:
