Indoor pool
I could use some help. My heater says lo and I still can’t find the issue. Water pressure seems to work. Filters cleaned. Temp sensor seems fine just need to find another possibility. I tested for continuity and they are working
What model heater are we discussing?
When did you last clean your filter?
What model filter do you have and what is the filter PSI?
Reactions: Mdragger88
