I know most people on here don't like the 3" puck chlorinators because of CYA buildup, and I understand that. But I've got 3 under 3, travel frequently for work, and it rains enough in Houston that generally the dilution will keep CYA below 100.
ANYWAYS, I just retrofitted my Hayward Tristar with a Century VS motor and did some testing on power consumption/flow rates at various RPMs. I noticed that my chlorinator will not have any inlet flow when the total pump flow rate is lower than 55GPM (I have a Blue-White flowmeter installed). I'd preferably like to run most of the day in the 30 GPM range for the energy consumption savings, but obviously I need to get chlorine in my pool too! Is there a way I can get water to run through it at a lower total pump flow rate? Move it from top feed to bottom feed? (I think this will help, but will then only over the tablet at the bottom)? Switch to offline chlorinator?
Not looking for a lecture on why this is perfect example of why I should switch to liquid chlorine. Ain't happening anytime soon. TIA
