I have an in ground pool and spa combo. I know my left pump is for the fountain, middle pump is filter pump and the right pump is the booster pump (picture attached)
My spa has about 10 jets and some of them are sucking instead of jetting out. I noticed that some jets are also stronger than others. This is also causing a cyclone effect
I know the filter pump is required to be on while running the spa heating pump but does the booster pump also need to be running while I run the spa?
What is causing some jets to suck rather than jet out water? I attached some pictures. Thank you in advance for help
