- Jun 5, 2013
- 144
I'm curious what options/suggestions you guys recommend for my current situation.
The past two winters, I've had a water level problem. During the summer, never had to add water. Even with kids swimming daily, water level was never an issue. However, it started last winter. The water level was stupid low, and I blamed the cheap solid cover I laid on the pool. I use a solid cover, and occasionally drain off the rain water that collects on top with a siphon. I figured the cover had a hole, and I wound up draining the pool water as well. However, this winter I used a new cover, should be hole free, but furthermore, we've had a dry fall. I really haven't drained the cover at all, and yet the water level is dropping dramatically. I just visually checked, and I'd estimate there's 18" of water left in a 4' pool. I do not drop the water level when closing, so it has lost 30" in about 4 months. Or about 7-8" per month. Seeing how the average rainfall in my area is around 4"/mo, this seems like it could become more of an issue this year.
Anyhow, further info, it is a liner pool, the only thing below the 18" line currently is the central drain. (Uniform depth pool, one drain directly in center of roughly 14x32' pool) I'd have to peel back the cover to check, but I suspect even the steps are above the water line now. (Bottom step is a feature of the concrete/liner, plastic steps terminate one above the floor level)
Ignore this until it becomes troublesome during the summer? Or is there a cheap fix while the water level is low?
I know that pool ownership isn't for the 'cheap fix' mindset generally, but I literally just quit my job to start my own business, and until I see respectable income, we're on a 'watertight' budget. Mmmm, poor pun there.
