This isn't a permanent fixture... but thought some of you might get a chuckle out of this...
Cleaning up a bunch of stuff around the yard after pool construction... including several pallets, some old firewood... and I had an old piece of stainless pipe that I had once used to heat domestic water from my wood furnace, so I threw it into the pool water loop and tried to capture some BTU's while burning my yard waste...
Water was running through my solar loop before it hit the fire... I suspect the solar was collecting more heat than the fire, but I was getting a 4 degree rise at 8gpm. I figured that was pretty decent for "free" heat. Day was warm (27 degrees), pool started at 15 degrees in the AM, was 18 degrees by suppertime.. 30,000 gallons. I'm happy with that for a single day gain. I really need a heat pump, but budget is going into concrete deck right now.
