kirbinster said:Why would switching the solar to a three way improve anything? Ball valves full open should have almost no pressure drop.
That particular comment only really applied if you were leaving the ball valves partially closed.
dschlic1 said:One of the big reasons for the increase in filter pressure was the installation of a check valve in the discharge of the filter. Check valve, while sometimes necessary, do produce a large amount of back pressure.
stever said:dschlic1 said:One of the big reasons for the increase in filter pressure was the installation of a check valve in the discharge of the filter. Check valve, while sometimes necessary, do produce a large amount of back pressure.
How many feet of pipe will a check-valve add? (I'm looking to you Mark S ) The way I have mine planned the water goes through three check valves. -- Too many?
Steve
dschlic1 said:At 75 gpm the 2" check valve installed by the solar people added about 5 to 7 psi to the pump discharge pressure.
