MITBeta
- May 28, 2020
- 1,216
- Vinyl
- CircuPool RJ-45 Plus
How are you getting your CYA number?Sorry to be MIA. We all had a stomach virus until yesterday so today is our first real "human" day!! We have had some pretty good rains over the past 3-4 days so the pool is in really bad shape. It is green and cloudy. I am sharing the latest test results.
Missy's test results
Pool test kit. Taylor K2006How are you getting your CYA number?
Yes, but the qualifier "just" puts a cap of sorts on "disappears".Disappears means you can't see it.
OK. You can't get an inbetween number for CYA using TFP principles. The easiest way I find is to just put in from line to line. If you can see it at the 50 line but not at the 40 line treat your CYA as 50. This number is the key number to be confident in for your SLAM as it determines your target FC level. Read the articles on testing CYA here and ask for help if needs be.
You need a couple of days where you can spend a lot of time at the pool and then you want to begin the SLAM process. Read the info, in full, several times. You will need enough liquid chlorine to do the SLAM on hand and you need to pull your pH down for starters. Make sure you have a good handle on the entire process before beginning.
I am a SLAM boss!! RAWWWWWRRRR!!! Also, we were gonna buy more chlorine but we got what they had. Apparently they r restocked so I will be going to WallyWorld tomorrow!!You have to follow the process...it will take as much FC as it takes and that will depend on a whole bunch of variables.
Poolmath suggest you will need 4.2 litres of 10%LC to go from 7ppm FC to the SLAM target 20ppm - if you are confident in your CYA number - for your 8500 gallons. You will need several jugs at a minimum I would have thought if the pool is green.
It's really important you take the time to understand what you are trying to do. You don't want to try and fix it by rote from someone telling you what to do, you want to manage the SLAM like the boss you are!
Hey all! SLAM started abt 3 hours ago, more or less. So far, so good??? I'm including the last several results plus the chlorine added. According to the chart, my ideal SLAM level is 28. My last reading was 35. Is my pool going to implode on itself?!! On my way to Lowe's or Wallyworld to get more chlorine. I need encouragement so I may have to stop for an espresso!!
Missy' Pool
Thank you!! I feel accomplished in a way. Hubby is on his way out to get a case of the liquid chlorine, without the espresso! You are right, I should stay away from them at night!! I will keep yall posted!!Looks good - you're already back below SLAM level. Don't sweat the quick blip to 35, just add a bit less next time until you get it dialed in, and test as often as you can. You're doing great, hope you got that espresso (although I would stay away from them at night!)
I had written it on a matchbook cover and just didn't xfer it to the appI am and I did
