Hi everyone,
We recently purchased a home that came with a beautiful pool.
This forum has been very helpful to get thru the first months of pool ownership - thanks for that!
I replaced the cartridge filters and filtration has improved significantly. Unfortunately the filter started leaking at the clamp / top and bottom half.
I have cleaned the O-Ring, tried it with and w/o silicone lube and tightened the clamp, but it keeps spraying when the pump is turned on. Leak (almost) stops after initial pump startup.
My guess is that the O-Ring needs to be replaced, the filter is > 15 years old. Can anyone help with identifying the model and share any other thoughts / ideas how to get this resolved.
Thanks so much
Thanks so much
