Chris,
Are you talking about the following info??? (Which I stole from one of our Experts...)
The Intellichlor keeps changing depending on the version, so it’s hard to keep up with what versions do what. They also hide a lot of useful information, which also makes it difficult to diagnose.
Pressing and holding the “More” button launches the System Status Mode. When the lights finish scrolling, the percent lights indicate hours of usage in 1,000s. For example, if the 40% light lights, that indicates 4,000 hours.
Version 3.1 on adds the ability to determine system temperature. Pressing the “More” button after the display shows 1,000s of hours of usage, will show temperature as follows:
Lights…………….....………Temperature
No LEDs………….…..………Below 30F
40%..........................36 to 45F
40% and 60%............46 to 55F
60%..........................56 to 65F
60% and 80%............66 to 75F
80%.........................76 to 85F
80 and 100%............86 to 95F
100%.......................96 to 99F
100% blinking……..….over 99F
All LEDs blinking……...Sensor bad
The temperature sensor is a 10k thermistor. Its resistance varies based on the temperature. The way it varies is known precisely. So the box measures resistance in ohms and calculates the temperature.
If the thermistor fails in a way that’s obvious to the software, the software will ignore the thermistor and use 75 degrees F as the temperature.
When using 75 as the default temperature, the salinity will be miscalculated by the software for any water temperature other than 75 F.
The further the water temperature is from 75F, the more error there will be in the salinity calculation.
If the thermistor drifts off calibration in a way that’s not obvious to the software, the software will use the incorrect temperature and the salinity will be off depending on how far the water temperature is from what the software thinks the temperature is.
I suspect that the software is probably getting a temperature reading in the high 80s or 90s.
One thing you could do is to cut the green and white wires. This should make the software use 75 F as the default temperature since it will lose contact with the sensor. This might make the cell work again.
You could measure the resistance of the sensor by putting the test leads on the green and white wires going to the sensor. The resistance should match a 10k thermistor chart. For example.
Temperature……….Ohms
60……………………… 15,310
70……………………… 11,882
77…………………….. 10,000 (The 10K reference point)
80…………………….… 9,297
90......................7,333
For example, if you measure the resistance as 7,333 ohms, the system thinks the temperature is 90F.
However, if the water is only 65 F, then the system is going to calculate the salinity as much lower than actual.
A light acid wash might help.
Increasing the salinity to about 3,800 to 4,500 ppm might help.
