IAquaLink not turning off water features after freeze protection ends
bard
0
Jul 10, 2016
23
Prosper, TX
Lately the water features turned on with freeze protection mode are not turning off after the air temp warms up and freeze protection mode is no longer active. In the app, the waterfall switch shows active and will turn off when asked, so it seems to be a Zodiac Automation issue. I don’t want to overlook the possibility that this could be an early warning sign of a hardware failure that could fail to turn on when it should resulting in freeze damage. Any thoughts?
What controls your water features?
A separate pump or a valve?
What does not turn off?
Did freeze mode ever work correctly with your water feature valve?
