Hi All,
New the forum, lots of great resources. I seeking some insight on setting up the iAqualink 3.0 (iQ30) controller. Whenever I try to add the controller, I get the message: "Enter a Valid Serial".
I've read all related posts I can find and can't solve. This is entirely new control setup. I had no controller installed prior, it was all manual, so I just installed both the Aqualink RS system specified below as well as the iQ30.
I've confirmed I have a network & Internet connection. I've connected the iQ30 both through WiFi and then Wired to eliminate connectivity questions. In both cases I get an IP address on my network and can ping the unit. All 3 connectivity lights on the iQ30 are lit up (PWR, LAN, WEB). I've also done a reset of the iQ30 and removed and added it to the network. I've also tried adding with the unit in every mode (Auto, Service, Timeout). The 4 wire connection to the panel is good and I've disconnected and reconnected to be sure. I continually get "Enter a Valid Serial" in all cases.
Any suggestions? I'm also wondering if it's possible the revision of the RS4 controller I received is not compatible with the Aqualink 3.0/iQ30? I see in the installation manual it states:
" For use with AquaLink® RS for Systems with Rev R Firmware or later For use with PDA for Systems with 6.0 Firmware or later". I'm including a picture of my board (which shows "RevT.2G") but I am not certain how to confirm the firmware compatibility.
Equipment Package: I purchased a new Jandy bundle & controller kit form eBay (.. I know). Here is the link:
JANDY IQ904PS POOL/SPA BUNDLE RSPS4 4 RELAY IAQUALINK AquaLink System Includes:
Aqualink RS 4 system for Pool and Spa Combinations
Thank you in advance for any insights. Below is the control board on my RS4.
Here's more info on my setup:Equipment Package: I purchased a new Jandy bundle & controller kit form eBay (.. I know). Here is the link:
- 2 Actuator Valves
- Four 3 HP Relays – System controls pump, heater and 4 Aux functions.
- 6612F Foundation Power Center.
- RS-PS4 Power Center electronics.
- iAquaLink 3.0 Interface Kit
