Used to work flawlessly for months without disconnects. It now appears offline and when I go to the box, all 3 LEDs are solid red, yellow, and green, which means no errors. When I check my router though, I do not see my iAquaLink connected to the router. It is on a dedicated 2.4ghz SSID. I can fix it by doing a reset and connecting to my wifi again but then it disconnects again in a few days. Even if it disconnects, why doesn't it reconnect? I am able to manually reconnect after a reset every time. Also the LEDs doesn't show any errors which is odd.
I've also done a wifi channel analysis and the channel I have it on is not in use by any neighbors.
Any ideas?
Any ideas?
