Is there a way (I was thinking of using a sock and letting it float around the pool or in the skimmer) to get granulated chlorine to gently disburse in the water without broadcasting it in to the deep end where some will settle on bottom and bleach the liner ?! FYI: I used Zappit 73% for years but near the end of last season (Maryland in August) I tried Doheny's Chlorine Super Shock. It has a 24-36 hr lag time before it peaks (compared to Zappit) but I was prepared for that thanks to all the education you have shared with me. Doheny's managed the heat, humidity, and sun of August twice as well as Zappit ever did. I literally mean I was putting in half as much chemical to keep the pool crystal clear. Must I bleach my new liner getting installed this month or is there a way to use Doheny's Shock with a liner ?
And yes, I've tried to find fresh, liquied bleach but it just isn't available in Maryland at a reasonable cost during the summer. THANK YOU SO MUCH... you all are a Blessing. -- Erica
