So I have been mapping out everything trying to understand all the things I am going to need to get this pool up and running once installed. When I keep getting to the 24hr timer I don't get how it will work with my pump or if I really need it at all.
My pump is an AquaPro 2hp dual speed pump (kind of regret this now after I read more on how the switch works). The manual says when you go from off to on it goes into high mode, then you have to flip the switch a 2nd time to get to the low mode. So I assume how the timer works is that it cuts power to the outlet and then when it hits the on time power comes to the outlet and as long as my pump switch is manually set to "on" it will run in either low or high mode I guess based on whatever mode it was when the power was cut off?
I'm still going to have to fiddle with the pump like if I add chlorine kick it to high then kick it back to low if i want it to run longer through the day. So if I have to fiddle with this pump anyhow, is there any real benefit to having a timer? Would it be mainly incase I forget to turn it on or I go away for a week stuff like that?
Also a 2nd part to this timer question. I have seen they have 240v and 120v Intermatic timers and I know my pump says it is 10.5amps on high 3.5 amps on low with a peak draw of 14a. Not sure which type of timer I would need in that situation. I do not have a SWG system yet but might get one next year so trying to take that into consideration as well when planning on what timer to use or if I need one at all. Thanks!
