I had a mildly (light) algae problem, so last weekend, I followed the instruction and added ~16oz Algaecide 60 Plus in the pool as the initial dosage, then I also added some liquid chlorine based on the Pool Math calculation. The water was fine in last week, and algae didn't show up.
This weekend (yesterday), I did a regular water testing and found FC was 0, I meant the water sample didn't turn red/pink at all. I thought it was consumed completely, so I used Pool Math and added enough liquid chlorine, then ~8oz Algaecide 60 plus for the 2nd time as the maintenance dosage.
Today, I checked FC again, and found it was still "0", the water sample didn't turn red/pink after putting 2 dippers R-0870. When I took a second look at the instructions of Algaecide 60 Plus, it said "Not to use together with liquid chlorine".
It seems I have made a mistake here, so what will happen in the water and what should I do next? Wait till the Algaecide 60 Plus all gone (then I can test FC normally)? By far, the water looks fine. And today's testing results are:
FC: N/A
CC: 0
TA: 60
Hard.: 60
CYA: <30 (I can still see the black dot quite well when it reached 30 mark, the highest mark)
Thank you!
FC: N/A
CC: 0
TA: 60
Hard.: 60
Thank you!
