Due to medical issues I let my pool get out of control and want to get back on the right track. When I started the slam the pool was green with algae(pretty sure mustard) with FC 1 , CC 2, CYA of under 10, pH 8, CH 800(very hard public fill water), TA 130.
The common way to lower TA as I understand it is to drop pH to 7 (which lowers TA) then aerate to raise pH up while the TA remains low. I believe that Matt says(on the vid) that aeration only minimally raises pH, if that's the case how does one achieve a lower TA without taking an inordinate amount of time? I just finished slamming my pool today, passed overnight chlorine loss test, and added CH to 24 which pool math tells me is correct for a CYA of 40. My TA before slam was 130 and I want to lower it.
I also understood Matt to say adding CYA raises TA, I added 5lbs of CYA to reach 40, be interesting to see the TA level when the pH drops to normal levels, if high pH even makes a difference in the TA reading.
thanks in advance, Brian
