Hi all, hope someone can give me a quick answer.
I have a 9m x 5m in ground pool and I have been losing about 3 inches of water a day. I decided to let he water drop until it stopped, it stopped level with the bottom of the vacuum outlet pipe.So I guessed this was the problem, I capped it off and refilled but it still dropped loads but has stopped level with the bottom of the skimmers. When I took the skimmer baskets out, you can see down the outlet pipe for about 20cm, then it kicks off. Well one pipe had water still in it and the other didn't, which I thought strange, so I got a watering can, filled that skimmer back up with water, then watched it drain away again in a few minutes.Im guessing the only reason that would happen is if I have a leak on that line and it must be a pretty major leak too. I closed off all the valves at the pump to make sure the water could back up and it should just sit there but it drained away really quickly, done it several times and same happened each time. When I fill the skimmer pipe up I fill to just a over where the top of the baskets are and then just watch the water swirl and drain in about 2 minutes.
Just wondered if any experts out there agree that this is the obvious problem
