While the pH is high, you have bigger issues to resolve first as you may be draining that pool.Well... now I am very confused. Should I do something about the pH?
Lets take a step back a bit......
How did you normally sanitize the pool? Is the pool a bromine pool, or a chlorine pool?
If it is a chlorine pool, you should have never added the bromine...... Whoever gave you that advise just caused you quite the headache. How much bromine was added?
If you have a bromine pool, you need to let us know so we don't make matters worse.
The following great advise was already given, but this is for a chlorine pool.
Welcome to TFP!!!
You have been given the "best advice" multiple times.
1. You MUST invest in one of the recommended test kits and stop trusting the pool store testing. (Done!)
2. You then replace water to get the CYA to a reasonable level (Could be lower, but at 70ppm is better)
3. You follow the SLAM process to eradicate the algae: SLAM Process (No mention of bromine)
4. Maintain adequate FC levels which are a function of your CYA levels (see [FC/CYA][/FC/CYA]) and you will never have algae again. (in a chlorine pool)
