JohnN
0
You are shocking the pool, correct? If so, follow the shock process (in my signature) until you meet all 3 criteria. The CC<.5, the OCLT<1 ppm, and the pool is clear.
Your post is a bit confusing.....did it turn pink when you added the five drops of R-0003?it said add 5 drops of R-0003 and if cc is present it will turn pink.
duraleigh said:Your post is a bit confusing.....did it turn pink when you added the five drops of R-0003?it said add 5 drops of R-0003 and if cc is present it will turn pink.
Nope, sorry. See red lines in my sig.whodat? said:The pool looks great. It actually did before I even started. So on goal B, the FC can't even drop 2 points overnight?
