Just replaced my heater element, refilled, and now I'm getting a leak when the pump runs. Leaking into the wiring box, so not getting much of a look at it for a couple reasons. ;-) Dried out the box once and did not see any water in there with pump off.
Most obvious candidate is the O-ring, though I'd expect that to leak all the time. I had the thing on the bench and felt pretty good about seating, but logically it's the smoking gun. Torqued down on those bolts some more, just in case but no change.
I did re-use the pressure switch, which I sealed with clear RTV.
Also, this thing doesn't have iso valves, Is there a way I can plug the pipes so I don't waste 400 gallons if I have to take the thing out again?
