as the R-0870 yielded no pink, according to the sheet, i have no chlorine.
since it'll already be clear, i'm just adding the first drops of R-0871 to set up the solution to test for CC)? should i just add like 12 drops of R-0871 to have a decent amount in there? also, since it'll already be clear, it appears there'll be no way for me to know my FC, since the only way i can determine FC is by knowing how many drops are needed to return to clear.
now that i'm at this point, i can test CC by adding 5 drops R-0003 to the already clear solution. if it remains clear, i have no CC. if it turns pink, then once again go through the process of adding R-0871 until it turns clear, which will then give me my CC (which would be amount of drops R-0871 second round x 0.5).
And then my TC will be my CC (if there is any) plus my FC(0).
all correct?
thanks
