It's time to replace the ball valves with nice Jandy valves. On the returns, you can see in the photo I just used two-way valves on each of the 3 return lines.
But on the suction side, I know it's popular to use Jandy 3-way valves to divert flow from the drain to a skimmer, etc. But the geniuses that installed this 20 years ago put the drain between the two skimmer lines! I've seen it done before with two three way valves if the skimmers are next to each other, but the only way I see doing it like this is having the middle one come up from below to a second 3-way valve mounted on its side.
So how would you do this? Just stick to two-way valves? Or is there some clever way you would do this with diverters?
