Hi Guys, after reading numerous posts about stripped threads on Hayward filter tie rods and their associated filter locking star knobs, I've concluded that the threads on the rod may have now become too worn. I need to replace the rod. The female side found within the star knob may also be stripped so I'll replace it too.
My question is, how is the rod attached to the bottom of the housing. Mine is still attached very securely. Is it just screwed in or is there a c-clamp or ???. If it's just screwed in (which I'm guessing 'cause I don't see a retaining clip down there, which direction do I turn it to loosen and remove it...CW or CCW? I'm assuming I can remove the rod with a vice grips or pipe wrench without dismounting the entire housing from the concrete slab????
Thanks in advance. I'm trying to save my self the $750 the pool cleaners want to replace the whole unit!
Kevin
Kevin
