Hello,
I know I am probably overthinking this, but I'd rather do it now then find out after the new patio has been poured... So any help would greatly be appreciated.
I am moving my pool pump from one side of the house to the other. I am finally at the place where I am moving the plumbing and for the most part every line is a cut and connect (no trivia). There is one return line that I am questioning, though. In the picture I attached, currently the water comes in from one end, hits a bunch of T's and ends at the last jet. In my mind, the incoming water flow pressurizes the pipe and the jets are the pressure release. Since I am now coming from the other side of the house, and only have access to part of the pipe, I am debating how to connect it. In order to replicate the current in-flow of the return pipe , I would have to run an extra 6' of pipe, drop in 2 90's, and create a kind of loop to hit the end of the pipe where it's currently connected. What I am debating is, could I do whats in the second drawing where I put a T mid pipe and replace the incoming T with a 90. Pipe wise, I can connect that without an issue and it would make for a cleaner install. My debate is, if the first thing the returning water hits is a T, would that negatively affect the flow since it will hit the wall and have to split? And as much as I would prefer coming in from the far end, I just cant access that plumbing without ripping up patio.
So that is my debate... anything would be helpful.
Thanks in advance.
Thanks in advance.
