I have two related problems. First my pool needs to be replastered. Second black algae started this winter. The black spots disappear after treatment with trichlor. The poor condition of the white plaster may have allowed the algae a place to start. Our pool is about 23 years old and I believe that the pool has never been replastered.
Late in the fall I noticed a rust stain in the shallow end of our pool. I had no idea what was wrong since I had never knew that a pool owner needs to replaster their pool. Since I started on the BBB method 6 years ago I have never had any algae. My SWG does not produce Cl in the winter so the FC was 0 during the winter. In previous years I monitored the FC as soon as the pool temperature reached 60 degrees. I was prepared to brush the algae with a metal brush and attack the black algae with a SLAM, copper algaecide, granulated trichlor and rubbing trichlor tablets on the black algae.
I now wonder if I should wait and attack the black algae after the pool has been drained. I could then pressure wash the pool, wash with a chlorine bath, and/or an acid bath. Since this will be the best opportunity to get rid of all black algae spores I want to hit the black algae hard now and not have to fight black algae for ever and ever. I might choose a colored plaster so Cl staining could be an issue in the future.
I currently am gathering bids to replaster the pool with Diamond Brite. I live in a rural area so I may have to contract with a plastering company over 100 miles distant. I plan to drain the pool and attack the black algae before the plastering begins. I want to have the pool replastered as soon as I can select a plastering company.
Questions:
1. To drain the pool should I use sump pump and the main pool pump?
2. What psi should I use to pressure wash? Should I use a broad tip or a narrow tip?
3. Should I start killing the black algae now or wait until the pool is drained?
4. When the pool is drained I will want to minimize the time the pool is drained. Would I be able to spot the black algae, brush it and kill it with bleach in one day?
5. What concentration of bleach should I use? e.g. 1:1? Should I use a pump sprayer or a sprinkling can?
6. Should I use the copper algaecide and granulated trichlor when the pool is drained?
7. Is there any reason to acid wash the pool?
8. How long does the pool need to dry before the plaster can be applied?
9. I have a sand filter using zeobrite. How should I sanitize my filter?
10. I have rusted rebar. How should this be fixed?
11. I plan to replace the hydrostatic valves. Do you recommend any other upgrades I should do at this time.
12. Any advise on how select and contract with a plastering company located in another city.
Questions:
