Unfortunately, no. We bought the house four years ago, and liner was already there. I don't even know when it was installed initially Should I start thinking about replacing the entire liner all together?Do you have any excess liner saved from where the steps were cut out to use as a patch?
Yes, that liner is pretty much at EOL (End-of-Life).Should I start thinking about replacing the entire liner all together?
Where do I start if I don't plan to do it as a DIY? I called a few pool builders found in Yelp, and no one does liner replacements.
Think small companies. The big guys in a warm climate probably only want $100k + plaster jobs. Search for pool services instead of pool builders. The pool service companies will either do it, or know who does.I called a few pool builders found in Yelp, and no one does liner replacements.
Vinyl-liner installation is not a DIY project. The required installation vacuum alone can cost $400 - $800. With a tear that large there could be damage to the wall and/or floor. Found these guys with a search, don't know anything about them: Residential and Commercial Services Provided by Local ContractorsWhere do I start if I don't plan to do it as a DIY? I called a few pool builders found in Yelp, and no one does liner replacements.
By submitting your info on this form, you are agreeing to be contacted regarding your service request by means of telephone, email, or text including using pre-recorded or auto dialed phone calls or text messages to the phone number you have provided, including your wireless number, if provided.
Consent to content doesn't require you to purchase service.
Please note you may be matched to one of our trusted partners such as CraftJack, Angi or Networx.
By using this service, you agree to our Terms Of Service as well as to Angi Terms of Service and Privacy Policy and CraftJack Terms of Service.
