Hi all,
I’m new to owing a pool. It’s an inground fibre pool that’s rectangular in shape and where its corners meet at straight angles.
The vacuum head that was included with the pool is basic (see photo). Its rounded shape doesn’t let it get into the corners to collect the dirt there. I thought a robot could help but even it doesn’t seem to be able to get in there. I’ve tried to brush the dirt away using the side of the brush but the brush head doesn’t get in there to let me gently push the dirt out and away from the corner.
What I’ve been doing (which only partially works) is disturb the water so that the dirt disperses back into the water and hope that it settles away from the corner so that the vacuum can get to it.
Thinking there must be a better method to clean the corners? I don’t mind manually vacuuming them. Would a different vacuum head help?
