We have an auto-filler and used it when we first filled the pool. It overflowed a couple of times, so we turned it off. We've been manually filling the pool since then.
I've been considering changing it out with a float switch that controls a an automatic water valve controller that turns the water source for the filler on/off based on the float switch.
Of course that adds other complications, but I can put some safety checks in (i.e. water valve on for more than X minutes, turn it off).
Before I go down this path though, I'm wondering how reliable are the normal, mechanical autofill/toilet valves and what is the likelihood I either have a bad valve or a bad setup by the PB? If they are generally reliable, I will skip the float switch method and instead add a sensor that tells me when water is coming out of the overflow pipe instead.
Thanks.
Thanks.
