At the bottom of every page in this forum is a link to "Old PoolMath Webpage". It may be old, but it still works. That is where you will find your answer. I plugged in some numbers for you. The newer PoolMath app also provides an "Effects of adding" calculation.
Install and setup your basic pool specs and then the main screen comes up with all the testing parameters. Click on any, such as 'FC' to enter your current value, your target, and in this instance which type of chlorine you'll be adding and it will tell you the gallons on the bottom.
You can add more parameters such as salt, temp and borates from the settings icon, if any are applicable to you. Turn on sharing from the same settings page and we can see your logs if you buy the premium version for $8 a year. Many times we can reverse engineer a problem or nip it before it even starts by seeing your logs. At least while you learn, it's the best $8 you'll spend.
At the bottom of every page in this forum is a link to "Old PoolMath Webpage". It may be old, but it still works. That is where you will find your answer. I plugged in some numbers for you. The newer PoolMath app also provides an "Effects of adding" calculation. View attachment 540460
