Currently building a 12 x 24 inground steel/vinyl kidney shaped pool, about 255 sq ft and approx 8750 gallons. The bottom is flat at 5', no diving and fiberglas steps. The customer didn't want main drains so I instead recommended two (2) Aqua Genie skimmers that have built in returns. The pool also has a separate standalone return, and now the customer wants two more returns added by the step seats. This will make a total of 5 returns and 2 skimmers in this pool. I am plumbing with 1 1/2" PVC and using a 1-1/2 HP variable speed pump.
My question is: will having 5 returns and 2 skimmers make the pressure at the returns too low? Should I plumb the step returns separately in a separate zone from the other 3 and use a multiport valve to allow the customer to select?
I'm new to the industry and could use some advice on this.
