That is one of the qualification that I made .... or intended to.
You may need longer run times for adequate skimmer or chlorine generation (with a SWG ).
What is the % output of your SWG if you are running 24/7?
If you cut the pump run time in half, just double the % output on the SWG ... etc.
Thanks for the advice! I keep the output set at about 30% most of the time. I will try increasing the output and lowering the pump run time and see what happens.
