We have a 6700 gal indoor salt water lap pool, with good equipment. I maintain the chemistry carefully, following TFP guidance pretty closely. Its retractable cover is closed except when in use. The water is always crystal clear, hasn't had any problems in years. It gets about 1-1.5 hour use per day when we're at home. I have been running the pump and filter about 8 hours/day. But we are often gone for a few weeks at a time. With that background, here's my question: Would it be ok to not run the pump/filter at all for a few weeks while we are away for the holidays, as long as the starting FC is high enough? In the winter the FC value doesn't fall much when the pool is not in use and thus not heated. And I am concerned that a small, intermittent leak from the pool heater (which might just be condensation) could turn into something more during our absence.
