Without replenishing the CYA that was broken down over winter, you have nothing protecting FC from UV degradation. How much CYA have you added and when? Can you post a full set of results?
Hmm, I'm not seeing your test results on Friday. Was it in a different thread perhaps?
Correct, overnight FC loss is caused by organic contaminates. I was talking about your loss between 5:30am and 10:00am, which would certainly be affected by low CYA. What kind of CYA did you add, liquid or granular? What method did you use to add the CYA?
Have you had an overnight chlorine loss of less than 1 FC? Yes = you're done; No = you're not done
No means you still have something in your pool eating FC that is entirely unrelated to CYA or sunshine. Test late after dark, test early before sunrise for OCLT. Brush brush clean clean everything during the day before.
Suzie,
I'm in the same boat as you. I was down to an OCLT of 3 for 3 nights in a row. Now I'm at 5-6 for the past week. This is my first year of trying this and I've about had it.
At this point if you stopped the SLAM you'd burn at least whatever FC you're losing at night EVERY DAY for the whole season instead of 1 or less. So over the course of a short season say 4 months that's roughly 120 days x 3 extra above normal usage FC = 360 FC. That's just under 11,000 ounces of 8.25% bleach in a 20K gallon pool. That's an extra 90 gallons of 8.25% bleach. $3 a gallon = $270. And that's if you don't get an algae outbreak due to not killing it all in the first place.
It should be short term pain, long term gain.
Ok, so the last time I tested was 5:30 a.m., this morning and we were at 16.5 for FC. I just tested again now at 10:00 a.m., and we are at 13.5. A 3 ppm drop when it's not full sun yet, about half sun, and the sun probably didn't start hitting it until around 8:00 (not 100% on that). Does this drop seem normal? CCs are 0.
If there are 0 CCs, clear pool, what would cause the FC level to drop beyond acceptable range, especially overnight?
You were at 16.5 this morning but what was the FC last night?
If you can not pass the OCLT there is something in the water consuming the chlorine and it will just take more time and chlorine to break it down. Having low CYA and high FC will lead to a larger than normal drop during the day such as you are seeing.
Two of the three criteria have been met, but passing the OCLT will complete the SLAM process and reduce your chlorine usage to normal this summer.
Always test before adding any chemicals or else you are flying blind.
Use 30 for your CYA level and do not add any more for now.
Congrats Suzie! Hopefully I'll be celebrating with you soon!
