PridgNYC
0
Re: How long can I go before not adding anything to new pool
The only difference between the K-1005 and the K-2006 is the FAS-DPD test which you will need, and a bigger box. You can order that test separately from tftestkits.com and will have spent the same amount of money as if you had bought the K-2006 initially. Also, the speed stir is a must have IMO, but you can do it the hard way (by swirling) if you can't justify the extra expense.
Backyard Luddite said:PridgNYC said:In my Taylor K-2006, the CYA vial is attached to Color comparator for pH, it is the smaller vial. Are you saying you didn't get any vials? Or did you not get the K-2006 kit?
Yes I didn't get the smaller vial with my test kit (Taylor K-1005). They apologized and already sent it out - should arrive tomorrow. I ordered this kit before learning about the TFP site. A friend suggested I get the smaller kit since reagents don't last more than a year and I was setting my pool up late. I plan to order the K-2006 next season. A little surprised Intex didn't supply some CYA test strips with the Sand & SWG combo filter since they supplied strips for 4 other tests.
