If I just leave out the flow keeper valve and adjust the other skimmer and the bottom drain it does great. No matter what I do with the flow keeper valve like change settings ect it just is so slow and does not climb the walls. Ran it for an hour with no flow keeper valve and it did well. If I block in the other skimmer and the floor drain with the flow keeper valve I end up with too much air in the pump. It crawls good then.
