Let me list what I think I know based on my recollection of the above posts (I haven't re-read in detail):
1. You started this season with fresh water from a city supply -- if this is true, you started with a pool full of water and zero cya.
2. You added granular stabilizer. Hopefully you measured this in the cap (if HTH brand) and a full cap is 9 oz. Hopefully you know how much you added - if so, report that to us. Also, in what way did you add it? Hopefully in a cotton sock hung in the water and then massaged once it saturated so it puffed out in clouds into to the pool water, pre-dissolved. If you added it in another way, report how you added it.
3. You have added bleach. How much, and how often? Hopefully a couple cups per day.
If my assumptions above are correct, you should have clear water currently. Do you? Also, if my assumptions are correct, you should have a fairly accurate estimate on your CYA -- it will be whatever your manual addition raised it. Report how much you added and we can come close on your cya for you. This assumes you don't have extreme splashout and frequent new water additions that would dilute it.
Regarding test kit - we need to know how much stabilizer you added (so we know your CYA) to know if that OTO (the yellow block test you have) will work at this point. Depending on your CYA, we can likely keep you clear with the kit you have.
I don't know how much algaecide is, but apparently you were willing to buy some. If it were me, I'd put that money toward this test kit. This kit will let you precisely test your FC and CC. With a fairly reliable estimate on your CYA, this kit could be enough to keep your pool clear all year. When budget allows, I would add the speed stirrer, but that is more of a luxury than a necessity. Here is the kit I'd get in your shoes (in fact, its what I got when I was in your shoes).
http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
I also started with fresh water (zero CYA) this season because I take down my pool every fall. I added enough stabilizer to get my CYA to 30 - I used the pool calculator and entered my known gallons and it told me what to add. I measured it out in the cap of stabilizer jar and let it dissolve. To test that I got to what I expected to, I should perform the CYA test about a week after my stabilizer addition. But I've been busy, it has been rainy (CYA test is best with sunlight) and I'm a little lazy. Regardless, I assume a CYA of 30 and have been bleaching daily to remain in my target zone based on the CYA/FC chart in Pool School. Crystal clear water and no issues at all. Eventually I will test the CYA,but since I know how much stabilizer was added, I could likely get by all year without that confirmatory test. You can likely as well, if in fact you are able to tell us how much stabilizer you added.
Don't give up. You can do this. Pool care really is just a steep learning curve - but then it is easy-peasy after that. If you can get the test kit I linked to, some of it will fall into place a bit quicker, in my opinion. Keep posting questions as needed!
