Hi guys, I'm a newbie.
I currently have a pool under construction that has an elevated spillover spa. I am working with the OmniLogic system so I have lots of electric actuators to work with and I want to make sure that the spa isn't heating the pool unnecessarily via the spillover.
Basically, how should I run the plumbing/actuators to make sure I'm not heating the pool while in spa mode? Do I need to make a 'loop' of sorts so that the spa drain is the only suction coming back into the spa returns?
Also, is there a thread on TFP or a recommended service which helps with the entire equipment pad design/plumbing/automation?
