OK, so the tile issue. Here is what happened.
Waterline tile went in about 2 months ago (seems like). It looked great and we were really happy with it. Then sometime about 3 weeks ago, we went out to mark the ones that were chipped so they could be replaced. We noticed some fractures in some tiles, and then more and more and more. The entire perimeter of tile had these fractures. It didn't mater if they were near an edge, corner, were under coping, wall ledgestone or just more tile.
This is a closeup of what the fractures looked like.
This section of tile is where we raised the pool beam wall for a planter box and ran the tile up and over the top and into the inside of the planter box. Tile was cracked on top and inside the planter as well.
We were completely flummoxed by this. Our builder had no idea what could have done that to the tile. They've installed plenty of glass tile and never seen anything like it. Regardless, it needed to get replaced.
In the meantime we reached out the the company we found it at as this was really looking like a manufacturing quality issue. They are an online reseller and seemed to be pretty well-known with lots of Pinterest references so at the time we ordered it, we felt pretty comfortable. They asked for pictures which we sent and the response we got back from them was.... sketchy... at best....
They blamed all of the fracturing on the lack of expansion joints. Period. They said they include a paper printout with every box of tile with installation guidelines. It talks about type of mortar and the need for expansion joints against all material change edges and every 8' to 12'. It was all pretty basic installation stuff that read like any full page printout of typical instructions for anything.
They primarily pointed to one of the pictures I sent saying that this was all caused by no expansion joint between the coping and tile line and the ledgestone and tile line.
My problem with that is that there was tile cracked like on that raised planter that didn't butt up to either. Essentially from my perspective, they are hiding behind a wide and encompassing installation guideline that most likely tends to not get followed exactly 100% by anyone. Who would want a vertical expansion joint on water line tile every 8 - 12 feet? I get the one against the coping. Sure, why not.
So I responded back questioning that if this was an expansion joint issue that I would expect some areas to have more and less fractured tiles based on what the butted (or didn't butt) up to. They had no response to this and just keep saying they include installation instructions.
I am not going to publicly mention this company's name since I think forum rules forbid it (unless an admin gives the OK), but this is something people should be aware of when ordering tile online. I guess there are good companies and bad and the amount of online presence doesn't dictate how well they would actually handle a problem.
Regardless, it was clear they were not going to stand behind their product. Our builder fortunately was able to find a 99% exact match to the tile from the NPT product line locally. The NPT tile is just a little bit thicker and bigger (and I wonder if this is on purpose to have a stronger pool tile to avoid an issue like mine). Other than that we took some of the original tile and butted it up against the NPT tile and it looks exactly the same. Same color and iridescence.
The only issue is that locally there was only 100 sq foot available and we needed 116 plus 10 that we want to keep for future repair needs. There is more up in Dallas and we want it all from the same dye lot so we are going to wait for it to arrive.
Our builder said that a big part of the issue here was ordering it online. They don't know this place. Can't walk in and talk to an owner they've been working with for 20 years. Lesson learned by all I guess.... The sad part is that if we had seen this available locally in the first place, we would have gone that road. Buying online had nothing to do about cost. We chose the tile because we literally did not see any we liked when looking at the local showrooms.
The saving grace here is a builder that stands by their name and took care of the issue.
plat.
