Hot pool - fountain - self aligning return - ideas?
Gnarbrah
105
Florida
Hi all - I see that I’m not alone with the hot pool problem (especially here in FL with no rain!!!). My issue is my return eye balls are not threaded. They are the press in bulbous looking things that just push into the return pvc pipe. I think they’re called self aligning? Any thoughts on how I can get a fountain connected? I’ve looked around the web and keep coming up empty.
Thanks!
It doesnt have to be part of your system. Build a pvc tree / T on the threaded port of a submersible pump.
You may be able to buy a spare fitting & modify it to fit a fountain- similar to how some do with their polaris fittings.
If it as cmp fitting they have several different ones - you just need one that you can glue a pvc pipe into
Thanks!
