One of our 3 Bobe Scuppers stopped working. I thought it was because the filter was due for a cleaning and so I cleaned the Pentair 200 Filter, which was pretty dirty - although the filter pressure only 16 vs the normal of 12. Didn't fix the issue, so I replaced the filter and that did not fix the issue. Skimmer basket and pump basket are clean. No water bubbles in the pump basket area. Unscrewed the motor and checked the impeller and it was clean, except for a very few stray hairs. When I restarted the system, I noticed that the Scupper works fine, but one of the other Scuppers is not working - so the issue shifted to a different Scupper.
If the Solar system is activated, all three Scuppers will sometimes work, of course the Solar cranks the RPMs up. If I turn off the solar, I can get all 3 Scuppers to work if I crank up the RPMs. (I also noticed that the pool may not seem to be skimming the leaves as well as it had previously)
As the pump/motor ages (it is 2 years old), is it normal for a higher RPM to be required to get the same water flow?
Thanks for your input
