Hello,
I moved into a house about 3 months ago with a 20k gallon inground plaster pool that was build in 2006. The previous owners used the same pool guy for the last 10+ years. He only ever uses pucks and powder shock. I asked him about the CYA and he said it's an old myth that doesn't matter. The pool is spotless and has always looked great since we have been using it. I cancelled the pool service a few weeks ago and started maintaining it myself. I had a pool at my old house and figured it wouldn't be too bad. I ordered some additional reagents for my Taylor test kit and as I guessed, the CYA is so high I can't even measure it. I was hoping to let it dilute out over the winter and not have to drain any of the water. When I first tested the water I had FC 0, PH 7.6, TA 170. I added about 90oz of 12.5% liquid chlorine, then slowly added about 60oz of 34.5% muriatic acid a few hours later. I diluted the acid with pool water in a bucket and added about 20oz at a time over about 30 minutes.
I went out to test the pool this afternoon, so about 6 hours after I added chemicals. The FC went up to 5.0 as expected, the PH went down to 7.4 as I also expected, however the TA actually went up from 170 > 180, where I would have estimated it went down to 150 or 160 based on the dosage of Muriatic Acid.
I am looking for some help here... Do I dose again with Muriatic Acid tomorrow? I have read that the maximum single daily dosage for acid is 90oz, is this accurate?
Current Levels
PH - 7.4
FC - 5.0
TA - 180
Current Levels
PH - 7.4
FC - 5.0
TA - 180
