So I have the TF100 test kit just got done with slam few days ago. I hadn’t checked PH during the slam. But initially I balanced everything out pool math, TFP recommended levels in the middle on all levels. PH 7.2 when started slam didn’t lower it. All levels are still good keeping FC within normal levels now not slam.
FC 4
CC 0
TA 120
CH 125
CYA 30
PH 7.2 still before and after slam
CSI -.61
I have read and re-read pool basics and chemistry levels.
I also read the further discussions on TA/PH.
I know PH if 7.2 is fine and TA of 120 not hurting anything focus on PH.
But my CSI level is just out at -.61.
So do I bother with lowering TA and aerate PH?
Post card that came with test kit said 100-120 for manual chlorinated pools. When I entered it on pool math was when I seen it should be like 80.
So of course I went straight to TFP forum for help!
Big thing is from everything I’ve read on here is that my PH should be rising because of it and it’s not, not a bit since getting levels where they should be 3 weeks ago…
FC 4
CC 0
TA 120
CH 125
CYA 30
CSI -.61
