Good afternoon,
My question is...
With a high CYA level, does the chlorine level effect phenol red in the usual way? In other words, should I be concerned about accuracy when testing for pH with a CYA level of 100 and FC of above 10?
No need to read further unless you're wondering why the high CYA level...
So I have discovered my pool is likely not 20,000 US gallons as previously thought. I wasn't careful and ran the CYA up to near 100 when opening a few weeks back when I was shooting for 80. With testing via 2006C, I'm calling it 95. I'm pretty confident in this range since I also ran a test with 50% tap water, which gave me a reading of around 50. I have no plans to drain any water. Instead I will perform at least weekly backwashes, which, won't do a ton, but I'm not concerned about this CYA level. The winter rain should bring it down a fair amount and I won't have to spend much on CYA next season. Also... everyone is loving the water.
Per Pool Math, I'm maintaining a FC level of 4-13 with a target of 7. It was 6.5 this morning. (Edited to change 4-11 to 4-13 after looking at the app again)
Given the amount of salt added, and the beginning and ending salt level as tested with a Taylor kit, I now estimate the pool to be around 18,000 gallons. Signature updated.
My question is...
