Control your pH, CH and TA levels and you will have no further problems. How often do you check pH? I would check it daily and keep it 7.2 - 7.5Hopefully this is the end of this nightmare for me.
duraleigh said:Control your pH, CH and TA levels and you will have no further problems. How often do you check pH? I would check it daily and keep it 7.2 - 7.5Hopefully this is the end of this nightmare for me.
duraleigh said:Normally, you would be "close enough" on your results but I think with your history I would adjust the numbers a little and keep them in that very narrow range. These are not normal guidelines but I think you need an extra safety margin because of the metal in your water.
pH - 7.2 - 7.5
FC - 4-6ppm
TA - 80-100
CH - below 250
CYA - 55 is just fine
Holding pH, TA and CH a little more restrictive than normal should keep you in a spot where you will never get the stains again. Keep you chlorine nice and even all season and enjoy your pool! Nice work!! :lol:
pH - 7.2 - 7.5
FC - 4-6ppm
TA - 80-100
CH - below 250
duraleigh said:You have reached the limit of my knowledge of metal stains. Others may chime in but I think I would lower the pH down to 7.0, hold it there a few days and see the effect
