- Feb 6, 2015
- 6,166
- Plaster
- CircuPool RJ-45 Plus
You will probably lose 1 to 1.5 times your pool volume per year here in the PHX area. Without a softener, your CH should rise 250 to 325 ppm per year. Being at around 1000 ppm CH in less than two years lends to calcium being added somehow. Maybe in a granular shock product being unnecessarily added?
In Chandler, I average an unsoftened tap water CH of 225 ppm and a TA of 120. Softened fill water CH is usually less than 50 ppm.
Do you have automation? If so, add that to your signature.
As an aside, having a 31k pool with an IC40 SWG (rated for 40k when running at 100% 24/7) will require longer pump run times at higher percentages in summer. When that SWG needs replacing, consider an IC60. We recommend a SWG at least 2x the pool volume.
- Are you using a speedstir when testing? Using one will provide more accurate results - and usually a lower CH reading due to consistent mixing. Twirling by hand and using ~40 drops of reagent can increase testing error.
- Holding the reagent bottles perfectly vertical?
- Dispensing 1 drop avout every 1 second?
- Letting the drops fully form on the tip and not forcing them off?
